Hey guys, like most of you, i suffer from horribly bad gas mileage. well, no longer will i be tyranised by my gas tank!
the cause:
i was looking through the wiring diagram for the speed sensor, and it appears that the computer uses a speed sensor signal from the trans. Now, if the computer does not have this signal than it would make sense that it would tend to run rich all the time cuz its not thinking that it is moving at all.
the solution:
hook the speed sensor wires up to the computer
the problem:
the speed sensor wire goes through a buffer chip located in the origional combonation meter (speedometer) in order to convert the analog signal into a digital one. this would be nearly impossible to hook up corectly.
the question:
has anyone who runs a late 80s 700r4/fuel injection setup corrected this problem? is there a way to bypass the chip? or reprogram the computer? if so, feel free to tell how. i truely believe this will drastically improve fuel economy. thank you, and sorry for the long post
-Brian M
