Originally Posted by
randygar
They'll all put out 24V if you use the proper regulator, even if it's a 12V alternator, although you might want to put a ballast resistor equal to the dc resistance of the field winding in series with the field.
--Randy
The best I have ever been able to get out of any 12V alternator is around 16-17 volts full-fielded. Anything like that tends to shorten the life of an alternator considerably due to heat buildup in the windings. Inputting 24 volts into one will probably just speed up the process a bit more.
Were it me, I'd either go with 12 volts across the board, or if you're trying to keep stock but add 12 volt accessories, then use a 24-12V converter.
Is there an issue with your stock 24V alternator? If not, I'd just fab up the bracketry to mount the A/C compressor and fly with the original. Other than space saving I can't really see an advantage to going to a smaller alternator.
