Thanks to everyone at the 'zone for a source of motivation and information.
Thought I would provide an update(photos to follow...when I finally figure that out)...
Frame:
Stripped, blasted, and re-finished. Rear shackle and hanger flip, steering box mod for 4-bolt box. AGR ram-assisted steering with high-steer.
Running gear: 35-spline D60 front with 4.56 gears. 14-bolt 35-spline rear with 4.56/Detroit and rear discs.
468 BBC/FI with TH475 and 203/205 setup using custom saddle style motor mount and crossmember.
Cab: 1978 J10 heater/defroster system. '86 Camaro tilt column. 1980's GM 1-ton truck swing pedal assy. with power booster.
Tires/Wheels: 42-15-20 Pitbull Rockers on 20x10 PSC Beadlocks.
Next up is rebuilding the doors...anyone know of or have a source for the window tracks, and seals?
THANKS
Roy
