Results 1 to 10 of 15
Thread: Scroll bars
    Default Scroll bars
    The scroll bars are showing again on the Galleries etc. pages when using IE.
    This revised open container code needs to be applied to the code for these.
    Attached Files Attached Files
    Thanks Amphi!
    Now...where does it go exactly?
    Sorry for they delay in getting back to this. Had to get some shut-eye after the red-eye. We are home from vacation now so; I can get back on this and some other ideas.
    I believe there two are files in your VB directory -- We revised both:
    spacer_open -- replace with the one attached above
    spacer_close -- remove one of the ending < /div tags
    This is how we did it last time. Maybe these quotes will help.
    Quote Originally Posted by amphi View Post
    You should probably also revise the Close Container to remove one of the ending < /div tags in the else statement to make the syntax pure.
    The revised spacer_open is in place and appears to be working great in both IE and Mozilla!!
    Took the 3rd div tag out of the spacer_close as well...no change noted, which is good.
    Glad you could run it down...I certainly could not have found it...heck I had trouble even locating the files to edit them.
    I hope this helps you recall how you did the changes -- We did so darn much, I had trouble reconstructing this one small change.
    Done!
    Wow!!
    Something happened – I'm sure you see it.
    Better double check the code.
    I have the original if you need it.
    I pasted exactly what you sent...
    You have the original...I would like a copy!!
    Here is the original.
    You can put it back.
    Let me work on it overe there.
    I see an extra character – a comma or apostrophe -- Just below each table.
    Removed that...still we have a narrowing running down the page....
  1. Scroll Bars on some screens?
    By amphi in forum Forum for questions and comments on the website.
    Last Post: February 26th, 2009, 01:43 PM
  2. tow bars/parts found in mil-truck Heaven
    By 503m715 in forum Open Discussion
    Last Post: July 6th, 2007, 05:05 PM
