Results 1 to 2 of 2
Thread: T-98 oil seals
    Default T-98 oil seals
    I was wondering is anyone has part numbers to the t-98 output shaft seal, or any other seal on the trans that should be replaced when servicing trans. Im in hawaii and info is hard to come by any help will be greatly appreciated.
    Jester Guest
    Only "seal" is on the rear mainshaft. There are some gaskets. If you have a leak its either the rear main seal or the bolts that hold the bracket to the back of the case.
  1. door to cab seals
    Last Post: February 5th, 2022, 08:34 AM
  2. Winch seals?
    By TWhetten in forum Stock Tech
    Last Post: December 3rd, 2007, 07:28 PM
  3. Door to cab seals
    Last Post: July 3rd, 2007, 02:52 PM
  4. Valve Seals
    By dhood in forum Stock Tech
    Last Post: March 16th, 2007, 01:04 AM
  5. NP200 seals?
    By Mikel in forum Stock Tech
    Last Post: February 27th, 2007, 06:50 PM
