Originally Posted by
jeepcj
I know most car and truck roll bars are round but all of my heavy equipment has square tube for roll over protection. I believe, but don't know for sure the the round stock is used on cars and trucks because it bends easier (as in a tube bender) it may also be stronger in the same wall thickness . The square stock I have has a much thicker side wall than most DOM tube I have seen. It is also structural steel (we made tanks stands with it). I have a few certified welders working for me so the joints will be strong. I may do some experimenting comparing the two
Square tube will bend at different levels of force depending on the angle of impact. Straight against one side will be very strong vs against a corner will be weaker. Round tube is equally strong from all directions. It was my understanding that given the same wall thickness, outside dimensions and alloy, round tubing is stronger than square.
The other consideration is ROPS on heavy equipment is a different animal from rollover protection in a truck/car. The ROPS in heavy equipment is designed for very low speed rolls onto the sides and only have to support the static weight of the vehicle. A vehicle cage needs to (1) be able to handle rolls from all angles as well as possible, (2) withstand the forces experienced in higher-speed (not necessarily 'high speed') roll-overs and roll overs from greater heights which is many times the static weight of the vehicle.
If it were MY life on the line, I would want DOM round tubing, well braced and professionally welded by someone who has experience building roll cages (ie race car or offroad fabricator), capable of supporting a 5,500#+ truck in a typical offroad or street roll over situation.
-Mudog
'67 M715 #165
521ci SFI BBF, 4R100/NP203/NP205
GM D60 ARB/10.5" Det/5.13s/11.00-16 XZLs
