OK I have a problem. My M-715 runs fine, buuuuuuuuuut ever so often while I'm bouncing down the road it starts to sputter and then die. No problem I know what to do. I pop the hood and then take the fuel line loose from the in flow side of the fuel pump, attach a rubber hose "I keep for just this sort of emergency," and then proceed to blow back through the line until I clear it or pass out, which ever comes first. I think the problem is the screen on the fuel pick-up tube in the tank. It is probably deteriated "is that spelled right" and is being sucked into the line. I saw a great post on how to replace this screen, but I have recently moved and do not have a shop or all my tools with me. So the big question. Does anybody know where I might find another tank that I can just swap out. Appreciate the help. Tony
