Results 1 to 10 of 13
Thread: rear winch
    Default rear winch
    So I traded the dodge bed for $300 and a warn XD9000I winch so I'm considering mounting the winch on a portable cradle and running powercable to the rear of charlie to use the winch off the rear but still be able to take it off I was going to wire my dodge up to use the same winch on it plus I could make a mount on my trailer and pull dead jeeps onto the trailer if I make a harness extension to plug into the dodge
    i would mount the winch to a plate and then weld a piece of 2 inch 1/4 wall square tubing. on the vehicle end i would use a trailer hitch reciever and some sort of electrical quick connect or you could get a really good set of jumper cables to hook up to the winch.this really works great and is very easy to do.what you have is like having three winches for the price of one. i wuold put a 2 inch receiver on everything i had front and rear.just pull the pin and quick disconnect and put it on something else. if i were you i would look into synthetic cable yuor back would appreciate it
    Excatly but I'm gonna make a plate with reciever and use different inserts to connect with both trucks
    Use solid 2 stock to connect to the dodge reciever and use a pintle eye insert to hook to the pintle on charlie
    More stuff to keep track but versitle
    I've already got the quik connects for 1\0 cable from work
    And can fab everything at work on the side
    Feb 2009
    Northern California
    I always use the 175A Anderson connectors for jobs like that - absolutely great product.
    --Randy
    One major complaint I had with a pickup I had was that I had a receiver type mount for my winch front and rear. Unless I put the winch in the front and left it there before wheeling, there were times I'd drop off into a hole or other obstacle, and then couldn't access the front receiver to insert the winch without some digging, or in rocks, jacking with the hi-lift.
    Likewise on the rear in some situations. Hefting a full size winch was never much fun either. With the plate, receiver and a full spool of wire rope it was heavy. Oh, and unless you use a double receiver system, side pulls are out of the question.
    Do like Gwen....1 front, 1 rear, one in the bed on the added bucket seats mount...so it can be safe until needed at either end.
    Quote Originally Posted by randyscycle View Post
    If I use the pintle system and designed my cradle correctly to protect the winch couldn't I pull sideways from charlie
  1. 10k garwood winch from rear PTO 205?
    By FlatlinesUp in forum Modified Tech
    Last Post: December 1st, 2009, 11:18 AM
  2. jeepcj : Rear mount pto winch
    Last Post: November 12th, 2009, 12:50 AM
  3. robertcowan : ramsey 8000lb rear winch
    Last Post: November 12th, 2009, 12:31 AM
  4. Show me your winch (BUILT) winch bumpers
    By bluesman2a in forum Modified Tech
    Last Post: June 21st, 2009, 01:45 PM
  5. Rear Winch Install w/ Pics
    By Jay Dog in forum Modified Tech
    Last Post: August 4th, 2007, 12:48 PM
