Results 1 to 9 of 9
Thread: Third Gear Noise
    Dec 2007
    Jim Thorpe PA
    Default Third Gear Noise
    I have been driving my truck on the roads around my house because they aren't municipal roads, and I don't have a plate. Actually I'm going for a plate this week, but anyway- I was never really able to get much out of second gear due to the hills and narrow roads. When I shift into third, there is a fairly loud rattle that comes from under the truck. I never paid much attention to it, I thought I was probably shifting too early, and shouldn't have been in third to begin with. Today I took it out and tried to get going pretty good, but the noise persists. I shifted into fourth, and it seemed to go away, but I'm not totally sure of that because of my speed at the time. I don't seem to lose any power or anything. Just wondered if anyone had any ideas.
    Dec 2007
    Jim Thorpe PA
    Probably should mention that it's the stock 230/T98a
    Feb 2009
    Northern California
    Well, what type of rattle is it? If it's clear, check for loose t-case and e-brake linkages. If it's muffled (internal to tranny), check the condition of the fluid. Check all the u-joints while you're under there, exhaust/muffler rattles, etc. I can't think of many things that make a rattle specific to what gear you're in, so I'm just thinking about general rattles that might resonate at just the wrong combination of engine/drivetrain speeds...
    --Randy
    Do you think it might be something a little loose that happens when the truck is at a certain speed combined with a certain engine speed that sets up the harmonics just right to cause it to rattle?
    Mine is full of rattles like that, actually. None of a type that cause me alarm though. Yours might be different.
    -- Tim Taylor
    Feb 2009
    Northern California
    Quote Originally Posted by Binford View Post
    Depending on where they come from, you might want to check the bolts that hold the t-case shift levers in place, the linkages, and the U-shaped end on the brake lever... fixed a lot of our random rattles that way!
    --Randy
    ...And break all the dried greasy gunk holding it all together?! Are you nuts?!?!
    -- Tim Taylor
  1. Clutch noise?
    By ralph in forum Modified Tech
    Last Post: February 22nd, 2009, 11:43 PM
  2. strange noise
    Last Post: October 1st, 2008, 11:17 AM
  3. What's that noise?
    Last Post: January 13th, 2008, 07:56 PM
  4. Granny gear crazy noise!
    Last Post: October 26th, 2007, 01:42 PM
