Okay,
I am finally getting around to doing the axle swap. I am starting on the rear and I want to make sure I am doing it right plus I have a few questions. This is what I have done so far.
1) Disassembled the axle.
2) Ground off spring perch on on side. Placed axle under truck, centered the axle, lined up the other spring perch to be parallel with the springs and tacked in the spring perch for the new position. I will do the other side this weekend. (Unless someone tells me I'm doing it wrong.)
3) I will be ordering the K77 rotors and axle rebuild kit this weekend. There is a little bit of rust on the ring gear but most of the guys I've talked to said to just polish it up as best I can and stick it back in. ($200 for new ring and pinion and it will be used mostly as a firewood truck.)
Have not decided yet:
1) Do I go with the cadillac calipers to retain the e-brake or do I add a e-brake to the transfer case.
2) Do I do the setup of the differential or do I have a shop do it. Pirate has an excellent article on how to do it but it does look quite involved.
Questions:
1) What shocks do I use and how do I go about setting up the shock mounts on the axle. I would like to set it all up, weld it, then clean it up and paint the whole thing.
Any ideas, suggestions or advice would be appreciated. I've done a bunch of searches in pirate and on this site which is how I've figured out how to get to where I am.
Thanks,
Rob
