Results 1 to 7 of 7
Thread: Axle Gear Ratio
    Default Axle Gear Ratio
    There's been a lot of discussion about the carriers and what aftermarket gear ratios are compatible with the stock M715 axles, but the information request is usually for a lower ratio for higher road speeds. I'm interested in something different. There are many times where I've wished for a lower gear. When in 4-low, I'd like to get to a creep when experiencing rough or deep terrain. When I use the term "creep", I mean that the truck tires rotate when I climb out of the drivers seat to help push.
    What gear ratios will fit that are higher numerically than 5.87?
    Winlock, WA
    Doubler transfercase.
    Or an Atlas 4 speed transfercase.
    Imagine your tcase options being, 1:1, 2.72:1,5.xx:1 AND 10.x:1 !!!
    Granny transmission of 6.xx, tcase of 10.x:1, and axles of 5.87:1.
    you do the math...
    Winlock, WA
    Oh, as for the axles, the Dana 60/70 ratios go a bit further, but you start dropping off in pinion strength, etc.
    Doubler tcase setups would be a LOT cheaper in the long run, offer more gear choices, and a much lower overall ratio.
    Thanks Hammer. That is certainly the correct solution. I didn't think of a doubler yesterday when I was "crawling" over some newly excavated and frozen earth berms. My mind just thought about the height of my tires and the "drop" in the advantageous 5.87 ratio, since I couldn't get to a nice low creep in the big bumpy stuff without riding on the clutch. Plus, I have no experience with doubler transfercases.
    A doubler would allow me to retain good highway manners that the 39" tires and NV4500 currently provides.
    I have seen 6.17 and 7.17 ratios for the D70...dont know if both are available any more OR if these fit the 60....
    Winlock, WA
    Normally, yes.
    But I don't know if they will fit the ones in OUR axles.
    That is true too...they have been made for the D70...but not necassarily OUR D70...
  1. Third Gear Noise
    By Pineyguy in forum Open Discussion
    Last Post: March 8th, 2009, 08:24 PM
  2. NP 200 to NP 205 speedo gear.
    Last Post: August 8th, 2008, 12:14 PM
  3. Air/fuel ratio gauge
    Last Post: March 23rd, 2007, 09:07 AM
  4. ratio formula question
    Last Post: February 14th, 2007, 02:32 PM
