I am going to use a mid 80's high pinion Ford d-60 front axle in my truck. The steering arms are cast as part of the knuckle and look like the steering linkage will hit the bottom of the front springs when installed spring over. However, aftermarket high steer arms look like they will hit the springs too. I know several members have done the spring over chebby axle swap. How did you do your linkage? How do stock chebby arms mount?
