This is how and what we started with. First everything was washed with deagreaser and scrubbed then allowed to dry. I like Castrol super clean because it does a great job and its biodegradeable.
I used a heat gun and a paint scraper to remove the decals. During this step I could see someone had removed what was probably the military decals with a grinder and gouged the door up pretty bad.
The tools I used for removing all of the offending yellow, this came from an Indian reservation I believe. Hence the yellow.
I made haste outside a day or two before the snowfall. It was pretty warm and a good temp. to finish up some sanding down to almost bare metal with some 80 grit on the Random Orbital attatched to shop vac, keeps the dust down.
I'll be posting more proper painting techniques later, stay tuned.
