As my story told, I lost my clutch at the same time my brakes went out. Just thought I'd post some pics of how I fixed that too. I guess I could have started another post but this is no big deal and is within 5" of the brake line junction... One more thing to check out while you are down below inspecting / replacing parts. I ran a search for the Napa # below and nothing came up, hope it helps.
The factory rod uses a thread on ball joint at one end and a crimped on joint at the other end meaning that only one end is easily replaceable. The inside joint on my truck was the crimped one and the outer was the one that gave way due no doubt to road related corrosion. If your pedal mounted joint is o.k. then you could probably get away with just replacing the thread on linkage end if its got slop. In the pics below you can see the joint that gave way along with my temporary zip-ty repair ( It don't work too good) and the new rod I machined up with the new ends. If I remember right, I used 15" of 1/2" round stock, machined 3/8 fine down 1 1/2" both sides. It went right together. Napa sells these Heim Joints which look be a replacement (thread wise) for the factory rod too. Balkamp part # 732-1133 to the tune of $14 a piece. Nice thing about these joints is they have the 3/8 stud (factory size) instead of an eye for a through bolt. Dont forget the jamnuts and washers as they dont come with the joint.
As always, thanks for keeping this site going guys, See ya, Jay
