While the snow is flying, I decided to rebuild the ignitor that came in the "parts box" with my truck. The truck now has a civilian distributor but I may put the ignitor in this spring to eliminate the 12 volt coil vs 24 volt system components. After I stripped and cleaned it, painted it and put in new points, cap, rotor, and coil, I discovered the lower roll pin on the shaft was sheared. Turns out the shaft is bent and this must have sheared the pin. Probably dropped. So, need a shaft assembly, to and including the coupling, and I guess I will have fun aligning it back to the proper orientation (+/- 180 degrees). I'll post a request in the wanted section unless someone has a source. Those parts are not even listed in the '34P so I assume you replaced the ignitor if you needed repairs.
