I had a perfectly running 715 until I decided to replace the plug wires and forgot which wire went to which plug. Long story short, I've got the engine at either top dead center or bottom dead center (the zero degree timing mark is at 12 o'clock) and took the following picture:
http://picasaweb.google.com/marianca...71465055068258
also here, if the first address is too long:
http://tinyurl.com/6ghdjo
Does the picture look like the rotor is pointing to cylinder #1? Or am I 180 degrees off and it's pointing to cylinder #6?
I just tried to start it and got an enormous backfire that sounded like a rifle, so I'm stopping for the night.
Many thanks for any suggestions.
