I know that I should just use the 10-1331 napa part numbered master cylinder that is suggested in annother thread, but I had used a corvette master cylinder on my Jeep CJ7 with four wheel disks and it worked great. The master cylinder (10-1331) is only a 1 inch bore cylinder. as far as I know the bigger the better since we have huge brakes right? The corvette master cylinder comes in either a power brake or a manual brake and the power master cylinder is 1-1/8 bore. The manual is 1 inch.
What do you guys think about using the power brake cylinder but as a manual? I may add the booster later. A new power brake cylinder is actually cheaper than the rebuilt one. The numbers for the master cylinders are for a 1975 corvette and the power one is ss4739018 and the manual one is ts101371
