Results 1 to 7 of 7
Thread: Stock t-case mounts
    May 2008
    Kansas City, MO
    Default Stock t-case mounts
    Does this look stock?
    Driver Side:
    Passenger Side:
    1967 M715 w/w #11812
    That's the stock case and mounts from what I can see.
    May 2008
    Kansas City, MO
    Okay, cool, I couldn't remember. I thought there was a single, wider cross member. These are a little twisted up, looks like the forestry guys did some serious off-roading. The rockers are dinged up, too.
    Agreed they are the stock mounts...agreed they are tweaked too...never seen that happen before...
    those are pretty hammered. the ones that were in my truck are strait as can be. you would have to be trying pretty good to hit those that hard
    May 2008
    Kansas City, MO
    I looked at it again. The rear cross-member is straight as a string. The front lip of the front cross-member is swept back out at the ends. Must've caught them on the rocks or something.
    I had to cut both of my crossmembers away from the bolts to get them off. They're stronger than they look! I thought "hey, let's just bend these flanges back out of the way." Nope.
  1. Replies: 4
    Last Post: July 3rd, 2009, 07:42 AM
  2. Let's see your Non-stock winch mounts
    By jlogan in forum Modified Tech
    Last Post: February 22nd, 2008, 10:29 PM
  3. Rebuilding the stock transmission and t-case?
    By fwdstuck in forum Stock Tech
    Last Post: December 19th, 2007, 12:24 AM
  4. Stock transfer case seals
    By vrod02 in forum Stock Tech
    Last Post: September 30th, 2007, 09:22 AM
  5. Confronting transfer case heat, stock NP200
    By brute4c in forum Open Discussion Archives
    Last Post: May 31st, 2007, 10:08 AM
