Results 1 to 2 of 2
Thread: Power steering pump mounting
    Nov 2008
    Tacoma, Washington
    Default Power steering pump mounting
    When modifiying to power steering, how has the power steering pump been mounted to the Tornado 230 engine, or has it been done yet? If not then why?
    I have seen it mounted below/outside of a GM style alternator...also, with the fuel/vacuum pump changed to just a fuel pump, the PS pump put above/outboard of the fuel pump, also on a bracket above the alternator and one person put a pump with remote reservoir on a plate that was under the fan with the pulley facing rear...pump in reverse of normal mounting.
    The only stuff we have pics of online is here:
    http://www.m715zone.com/vb/view.php?...power_steering
  1. Power Steering Questions / Which box & pump to use?
    By dukhunter785 in forum Modified Tech
    Last Post: January 13th, 2023, 11:09 PM
  2. uscgmatt : dodge power steering pump
    Last Post: November 11th, 2009, 05:56 AM
  3. Power steering pump
    By Kamikaze12volts in forum Modified Tech
    Last Post: September 20th, 2008, 10:23 PM
  4. Power steering pump??
    By DivingKaiser in forum Modified Tech
    Last Post: December 29th, 2007, 11:12 PM
  5. Power Steering Pump Mount
    By Rumplecat in forum Modified Tech
    Last Post: March 19th, 2007, 12:39 PM
