Thread: Braden winch question
    Dec 2007
    Jim Thorpe PA
    Default Braden winch question
    I had a little project planned for work tonight, but I forgot to get the necessary measurement when I left- can someone help out? Not sure if they all have it, but my truck has a piece of angle (now bent in half with a torn bolt hole) as a sort of backstop on top of the winch. All I need is the distance between the centers of the holes and the bolt-size. Thanks!
    Last edited by brute4c; November 5th, 2008 at 10:05 PM. Reason: hit edit button by mistake...no edit was done...
    Wish I had a winch....again...
    Jester Guest
    The angle iron bar on top?
    14-1/2" center to center and 1/2" holes
    Dec 2007
    Jim Thorpe PA
    Awesome! Thanks alot.
    Sep 2008
    Stevens Pointski, Wisconsin
    You should have two of them, one on the back nearest the readiator and one almost in the middle. The -34p shows them. Both are the same. I just picked up the angle iron today to replace one missing on mine. Material thickness is 1/8 inch and is 1 1/4 x 1 1/4 inch angle.
    Scott
    Dec 2007
    Jim Thorpe PA
    Thanks, I saw the other 2 bolts forward of what was there and figured there was something missing. I'm working on doing something different up there and wanted to get started. Any idea what the pieces are there for? I assumed the one that was there was supposed to stop the chain/hook from pulling into the front of the truck.
  1. braden winch rebuild
    By jaymzm715 in forum Stock Tech
    Last Post: January 15th, 2009, 12:15 PM
  2. Pros & Cons of the Stock Braden winch?
    By dukhunter785 in forum Open Discussion
    Last Post: December 19th, 2007, 11:13 PM
  3. braden winch
    By maccj715 in forum Open Discussion
    Last Post: May 25th, 2007, 08:10 AM
  4. Roller Fairlead for Braden winch
    By room4ten in forum Open Discussion
    Last Post: February 2nd, 2007, 08:38 PM
  5. braden pto winch
    By Nuke_afftaburner in forum Modified Tech Archives
    Last Post: March 26th, 2004, 09:48 PM
