I had a little issue with the yokes from the NP 200 fitting on my NP 205. even though the chevy version of the NP 205 is supposed to have the 10 spline shafts, mine has 32 spline. I wasn't about to spend money on new yokes or those expensive ($22.00 a piece) conversion U-joints. I came up with a solution and thought I would post it just in case someone else would like to do the same and save some cash. here is the pic of what I did to modify my original 205 yokes. I drilled a hole and tapped it to 1/4 inch threads. I would lock tite these to be sure they don't move. I used a washer for a 5/16 bolt so I could shift it further over and bend it. I used a punch to bend the washer. Its kind of hack, but it should work with no problems and its way better than buying three new yokes. It will use the strap type clamps, so you still have to buy three sets of the clamp kits, but that is far cheaper than the conversion U-joints and you only need to buy the strap kits once. There is a conversion that will allow you to use a strap style yoke with U-bolts out there just so you know. all you do is drill out the threaded holes in the yoke and put in the special U-bolts that come in the kit. I believe that Four Wheel Hardware sells them.
