Results 1 to 10 of 18
Thread: Gas Gauge
    Jester Guest
    Question Gas Gauge
    Its driving me crazy. Bought a new gauge set from NAPA - got the part number from another thread here. Put it in and as soon as the gauge gets power it pegs. I think a short in the wire to the sender.
    Run a jumper wire from the sender to the gauge. Does same thing. Run a jumper from the battery and a jumper from the sender. Does the same thing.
    What is up? Why would the gauge peg full? This is what the old gauge/sender did that I replaced.
    HELP!!!!!!!
    Did the sending unit you're using come with the gauge? They are generally matched to work together, so if you have a new gauge with the stock sending unit, they may not like each other.
    BTW, I have a box of small parts and some tires for you here at my place.
    -- Tim Taylor
    Jester Guest
    Quote Originally Posted by Binford View Post
    The gauge and sender were a set from Napa. They are matched. No idea why they are not working.
    I will get with you to get the parts/tires. I am excited.
    R T F M ?
    And check your grounds. Always check your grounds.
    -- Tim Taylor
    this may be simplistic but is it a 12v gauge on a 24v system?... or versa vicey
    Jester Guest
    Quote Originally Posted by 5quarter View Post
    Wish it was that easy. Nope. Truck is coverted to 12V and the gauge/sender is for 12V.
  1. 24v ro 12v gauge question
    By Duane in forum Stock Tech
    Last Post: September 10th, 2009, 05:44 PM
  2. M35A2 Gauge Panel?
    Last Post: January 19th, 2009, 11:29 PM
  3. Gas tank gauge
    By vacca rabite in forum Stock Tech
    Last Post: June 1st, 2008, 07:01 PM
  4. volt gauge
    By koobster in forum Stock Tech Archives
    Last Post: February 22nd, 2004, 01:41 AM
  5. Fuel Gauge Sender
    Last Post: February 12th, 2004, 01:31 PM
