Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Spark plug questions
    It sounds like you my have the military ignition that someone used the civilian plugs and wires on...it can be done and done well, it can also be done poorly...got a pic??
    Jan 2008
    Montreal Canada
    got a pic??
    Will take a pic tomorrow ........ i don't have any real good underhood pic.
    Rockwells / Cummins / 3053A
    Combat wheels on 395 XML
    M104A1 trailer
    Jan 2008
    Montreal Canada
    Here the military distributor with civilian wires .... it's a clean job because i do not notice until i realized that i'm not having the good screwed type plugs.
    M104A1 trailer
    Definitely the military ignitor...unit with the coil and distributor in one housing...civilian plugs and what might be the mil wires coming out of the ignitor spliced to civvy wires after about an inch or 2.
    If you plan to keep this setup for now, use the Autolite #275 or equivalent plug.
  5. #15
    Jan 2008
    Montreal Canada
    They were some motorcraft plugs installed ... i changed them for the Autolite ones but they are not the 275 because any auto parts got thems in stocks ... so a changed them and the truck is running like a new one !!!
    M104A1 trailer
  6. #16
    Jan 2008
    Montreal Canada
    the plugs i used are Champion 929 ... the ones used to be on the truck were Motorcraft AL7C ... they didn't look the same ... the 929 were a little longer but they worked fines.
    As long as the truck is running fine . that's the most important !!!
    M104A1 trailer
  7. #17
    were you able to screw in plug wires on the 2344 plugs?
  8. #18
    Jan 2008
    Montreal Canada
    Been a long time since i worked on the oem engine. Mine was mod military/civil so can't answer on the 2344 plugs. Now having 6BTAA engine so plugs are no longer a problem
    M104A1 trailer
  1. Help on spark plug type
    By viperman in forum Open Discussion
    Last Post: September 19th, 2018, 08:51 AM
  2. spark plug removal
    By 14fan in forum Open Discussion
    Last Post: November 3rd, 2009, 11:42 PM
  3. spark plug gap
    By 14fan in forum Stock Tech
    Last Post: March 17th, 2009, 10:44 AM
  4. Spark plug wires
    By Mater715 in forum Stock Tech
    Last Post: August 2nd, 2008, 05:47 PM
  5. spark plug # FOR THE 230
    By angler in forum Modified Tech
    Last Post: June 25th, 2007, 04:40 PM
