Pulled the cover off the rear diff to change the fluids. Is using a gasket on the cover recommended or just seal it back up with permatex?
It all depends on who is going to be replacing that fluid next time
um that would be me.
Thinking about an aftermarket cover with a drain plug to make changes quicker/easier.
I just changed the oil in my front diff and only pulled the cover because it was leaking. There is already drain plug in the bottom of the housing (unless you have a non-stock set-up.) I ran out of oil, so I didn't do the rear, but I think there's a plug back there too. I used permatex on the front cover.
Last edited by Pineyguy; September 29th, 2008 at 12:30 PM. Reason: Bottom of housing, not cover clarification
I used to be cautious about using permatex or any kind of gasket sealer only as the sealing agent, but now I do it on almost everything and don't get leaks at all. Put it on, let it set up a bit, then bolt the parts together.
68 M-715
67 M-725
If you're going to use it, use the minimum amount to get the job done.
When it squeezes out and falls off on the inside it blocks oil passages, filters, screens and so on. The pinion bearing on the axles relys on fluid being thrown into a passage and then gravity drains to the bearing and back to the pan. Doesn't take much to slow down a non pressure system like that. Same goes for blocking return oil passages in the cylinder heads and such.
I'm with Doug......Remember, however much you see squeeze out is also what is going inside the component as well.
