Results 1 to 10 of 13
Thread: Brake parts
    Default Brake parts
    Trying to source wheel cylinders for a 67 M715, preferably from the local parts store. Anyone have part numbers? I searched and found a potential MC replacement from a Jeep Gladiator bendix part BXH 11331. I would love to hear any feedback from this application.
    Thanks,
    Robert
    For the wheel cylinders, use '91 Ford E-350 cylinders - you will need to slightly enlarge the mounting holes. I used a dremel tool with a carbide bit. Basically, make the mouse ears for the mounting holes larger in a down and out direction. You'll see when you hold the new wheel cylinders up to it.
    That is a good master cylinder number - I used the Cardone version 10-1331 on my truck. You will need a dual master cylinder adapter from Napa and a couple of other brass fittings, depending on what size line you use.
    I left the front brakes on the original proportioning valve, and used a plug on the back of the proportioning valve to block that. Then I ran a new line from the rear feed line to the master cylinder.
    Clear as mud?
    The wheel cylinder part numbers for the ones compexp posted above with stainless steel pistons are:
    93-94 Ford 1 tons.
    Tru torque part numbers W37262 and W37263, left and right.
    The following are part numbers for one side, not sure which off hand
    Bendix 33595
    Raybestos WC37263
    EIS EW73615
    Wagner F73615
    I just ordered new M715 wheel cylinders from Memphis. Cost was $34.11 each.
    Can buy the more modern ones for $12-14 each at Napa.
    So the Ford parts essentially bolt right on, and have stainless liners so they don't rust and let the seals give out?
    (like my 3 year old stock replacements did?)
    and, they're cheaper?
    what's the downside?
    Are the 91 and 93/94 ford parts listed aboe the same thing?
    1 ton...two or four wheel drive? Dual or single axle? I've not heard of Auto Specailty, or Torque brands...
    The down side to the Ford wheel cylinders is the first time you mount them. As pointed out above, you have to enlarge the two mount holes out/down a little. It might take you an extra 30 minutes the first time. After that, you are good to go.
    I have been running them on all four corners of my truck for almost 4 years now. No leaks, no corrosion and good brakes.
    This was just talked about the other day. Follow this link. And checkout the included links.
    My new truck
    Welcome aboard.
    Wart Hog
    The piston is stainless not the cylinder!
    68 M-715 MVPA #2710
  1. Brake Parts Needed
    Last Post: January 15th, 2015, 09:00 PM
  2. j20 parts
    Last Post: November 19th, 2009, 11:31 PM
  3. fisherman : Brake line pressure switch for brake lights.
  4. brake parts
    By george walker in forum Open Discussion
    Last Post: July 25th, 2007, 03:16 PM
  5. Parts for all
    By spr-m715 in forum Open Discussion
    Last Post: January 4th, 2007, 09:33 AM
