Results 1 to 6 of 6
Thread: putting fsj lift kit on m715
    Default putting fsj lift kit on m715
    how easy or hard would it be to mount a fsj lift kit on the m715 mounts. these would have to be relocated.
    how easy is it to change 24V into 12V system?
    what about the lights, etc..
    tnx
    d
    To go to 12 volt, change the alternator, change the bulbs to 12 volt equivalent...find the conversion page for bulbs here:
    http://www.m715zone.com/vb/pages/man...rsionChart.pdf
    Change out the gauges, besides the speedometer, and the sending units.
    If you ave the early style turn signals with the large distribution box under the hood, you need to modify the flasher unit in it or change out to the laer style, solid state units that also came stock on these trucks...I did the swap like this:
    The horn will work on 12 volt, just not very well...good to replace it with a 12V unit.
    That covers it I think...well...you can get rid of 1 battery or wire them in parallel instead of in series if you like
    thanks for the reply! i'm gonna start working on it ASAP.
    any idea on the fsj springs???
    Leaf springs beween the FSJ and the M715 dont work...different lengths for sure as been posted...different mount sizes to I think.
    About the only thing that is the same is the 2.5" width.
    Winlock, WA
    Not only are they different, but the stock M715 springs are about equal to 4" lift springs for the FSJs.
    So to gain any lift, you would need to get the 6" springs, and change all the mounts out.
    If you want to change the mounts out, get the 2 or 4" lift springs and do a spring over for more lift. You will get a softer ride with better articulation. But it's a bit of work, welding, fabrication (nothing new on these trucks).
  1. body lift kit from a J10 and J20 work on M715
    Last Post: December 2nd, 2009, 10:34 PM
  2. Finally putting in the 460
    By ivan in forum Modified Tech
    Last Post: August 27th, 2009, 09:09 PM
  3. How much lift needed for 40"-46" tires under my M715?
    By BrutusM715 in forum Stock Tech
    Last Post: January 13th, 2008, 11:59 AM
  4. Manufacturing M715 Lift Kits
    By BulletSponge in forum Modified Tech
    Last Post: April 13th, 2007, 12:00 AM
