I am running a 6bt so of course i have the cam driven power steering pump. I am also running a hydroboost brake set-up. The question is. Do you think i can still you a FSJ steering box? or should i use a 1ton dodge steering box and just fab it up to fit. The big question i have, are the steering boxes sensitive to pump pressure's? Or can you almost use any pump with any box? I have an 1ton dodge power steering pump and steering box to use as a core at Autozone. Just undecided as of now.
