Results 1 to 5 of 5
Thread: trans drain plug replacement
    Default trans drain plug replacement
    The drain plug for the trans has some how gone missing. Does anyone know the size? Is this part available at NAPA? Thanks for the help.
    3/4" pipe plug from the hardware store and you should be all set.
    Thanks for the quick response. Your recomendation for type and brand of fluid? Thanks from a newbie.
    Any good gear oil in the 80W-90 range should do...if it gets consistently below 0 there, go with synthetic...75W90 is what mine gets...synthetic always a plus if the seals are good.
    Thanks for the info, I'll be back in action this weekend.
  1. gas tank drain
    By Loope in forum Stock Tech
    Last Post: February 7th, 2010, 11:57 AM
  2. Gas tank drain rusted shut.
    By vacca rabite in forum Stock Tech
    Last Post: October 27th, 2009, 02:11 AM
  3. Radiator Drain
    By Barrman in forum Stock Tech
    Last Post: October 22nd, 2009, 02:33 PM
  4. Transmission Drain PLug
    By Mater715 in forum Stock Tech
    Last Post: July 26th, 2008, 10:52 PM
  5. Windshield Drain
    By Barrman in forum Stock Tech Archives
    Last Post: March 27th, 2004, 10:39 PM
