Results 1 to 9 of 9
Thread: rear trans seal
    Default rear trans seal
    is the rear trans/yoke seal the same as the transfer case seals? if not, does anyone have Napa/federal or any other aftermarket number?
    Thanks
    Duane
    Duane, no answer for you, but stock trans is a T-98 if that helps the parts counter guy help you find it. Worst case, call Novak.
    Dont have any part number but it MIGHT be the same as a T18 trans...the T98 and T18 are pretty similiar with the T18 having better oiling and a different to the bellhousing bolt pattern.
    Jester Guest
    Quote Originally Posted by Duane View Post
    Thanks
    Duane
    Got a part number to post? I am thinking about replacing the rear seal since the t-case is out right now.
    canby Oregon
    They are the same as a t-18. In fact I should have a few in the garage. I will see what part no. is on one of them.
    canby Oregon
    I can not make a positive id on the seal, but this is what I think is on it. sc 175/125/25 tto/d431/1 It is aprox. 1 3/4" dia. and has aprox. 1 1/4" inside dia. There is 3 of them in the kit, so I think this is the one you are after. (You use 3 on a divorced trans and 2 on a married) looks small, but I have been playing with big truck parts lately.
    Jester Guest
    I am still working on getting a part number for this. Will post it up when/if I do.
    Jester Guest
    Timken web page shows p/n 450308.
    Application listed is:
    JEEP TRUCK - Comanche, FC Series, Gladiator, J Series, Pickup Truck, Sedan Delivery, Utility Wagon 4-SPEED MANUAL TRANSMISSION - Rear Output Shaft 1967-1955 - (Warner T98)
    I am going to get one and see if that is it.
    let us know, because I still need one.
    Thanks
    Duane
  1. need part no.or Xref. for Trans.Case rear seal
    By Traynter in forum Open Discussion
    Last Post: March 12th, 2010, 09:31 AM
  2. Rear Main Seal Question
    By drose5432 in forum Open Discussion
    Last Post: February 25th, 2009, 03:03 AM
  3. Rear Main Seal
    By rboltz in forum Stock Tech
    Last Post: March 25th, 2008, 08:48 PM
  4. 350 rear main seal ?
    Last Post: January 11th, 2004, 08:34 PM
  5. Rear Main seal questions
    Last Post: January 6th, 2004, 05:50 PM
