I finished most all the heater work. I started pulling the front sheet metal. I am removing dents and aligning cracks to weld up. This is on the front radiator support.
I have a couple questions.
One of my radiator side mounts has been reattached. And doctored some. I am going to remove it and repair it to look untouched. Then reweld it back on.
Could anyone with a truck handy measure the gap between the radiator side channels?
This measurement right here. Exact please...
The top was cut off. I will put it back. Plus the bottom was welded. I think it broke or something. I will make all the repairs go away.
Question,
Are the two body mounts the core support sits on the same size as the cab body mounts? The thickness or height of the biscuit?
Got most all the dents out. A couple small cracks to weld and back on it goes for a fit check.
Question number two,
Does anyone have the seal number for the steering column bell under the steering wheel. I have ordered a couple seals and they are the wrong size. I was told there is a NAPA number. I am not finding it.
My flat GM leaf springs showed up. The UPS driver tossed them through my gate right on the ground when there is a big drop box 8 feet away. Numnutz..
I feel like I am making some fair progress. There is a lot to do still.
Thanks ahead of time for anyone who can answer my questions.
