Looking for any info on purchasing the rubber door stops for my M715
And they go where exactly? Many are the same as full size jeeps. Wagoneer and J truck. I will probably have time to go look at where they go later. But if you know maybe post it up.
They on the right side of the door frame half way up it’s a small round rubber stop
1/4x1/2
Joseph
I ended up making them. In the same thread, someone mentioned that they were also commercially available but I don't think their link works.
http://www.m715zone.com/vb/showthrea...-project/page3
I think I have some of them. They were a common little bumper. I will look tomorrow as it is late. I will look for a part number or a link I am pretty sure I have somewhere. I will probably need the ones I have.
Searching the internet is difficult now. Here is a bag of 50 of them. About the correct size but not tapered like OEM. The bumpers also should have a washer in the bottom of the screw hole for strength. The originals do.
The search result that works best is "recessed rubber bumper"
I will look more later. But you get the point...
https://rivers-edge-products.com/sho...rubber-bumper/
These are just about perfect for size but the FSJ ones had a flat top not rounded. And they were tapered. If that does not matter here is a life time supply.. The replacements should be very soft. I have seen the corner sheet metal skin crack from bumpers that were too stiff.
https://www.ebay.com/itm/17410687119...Bk9SR-jEhvbXYQ
