fisherman : More Pics
More Pics
Post by fisherman on Jun 4, 2006, 9:19pm
http://img126.imageshack.us/img126/1...s0319pt.th.jpg
I'll finish sending pictures now that I think I've figured this out. buick 350 with t-98 bolted up. Trans will sit in factory position. However I'll be fabbing up a new mount for the trans and np205. Still have to run bolt thru the engine mounts and finish torching off the top of the factory engine mount. Will then final weld engine mount to frame.
http://img393.imageshack.us/img393/3...s0346ia.th.jpg
troop seat sprayed with other parts.
http://img393.imageshack.us/img393/4...s0354wa.th.jpghttp://img126.imageshack.us/img126/8...s0366cc.th.jpghttp://img126.imageshack.us/img126/3...s0380ss.th.jpg
luckypabst :
Re: More Pics
Post by luckypabst on Jun 4, 2006, 10:32pm
Beautiful!
That bellhousing is nuts
Chris
fisherman :
Re: More Pics
Post by fisherman on Jun 4, 2006, 10:42pm
It's a factory bellhousing and input shaft that is longer probably from a J truck. I bought it from another member with the retainer bearing, input shaft and bellhousing. FED SUCKS lost the bellhousing in transport. I sourced another bellhousing, rebuilt the transmission new bearings and seals and longer input shaft. The only part I had to fab was the pilot bushing. Everything bolted up and is all Jeep. Yes buicks came in Jeeps. I'm on the downhill part. Finish painting, a little more fabbing and putting her back together. Todd
luckypabst :
Re: More Pics
Post by luckypabst on Jun 4, 2006, 10:54pm
Yea I knew it was Jeep. It's just amazing what they went through to fit an 8 where a 6 was. I'd rather just engineer different motor mounts.
Chris
fisherman :
Re: More Pics
Post by fisherman on Jun 4, 2006, 11:00pm
The engine mounts came from a 69 J-3000 same truck as the engine. They go in the same spot as the factory M-715 mounts did. I used a through bolt from the top shock tower to position them. I had to torch out the studs though from the M-715. I will drill and add a couple more bolts to the mounts. Then add some welds. I don't want to rely on just welds. What I was happy with is the tranny ends up in the same factory position. I would then be able to possibly bolt in any BOP engine. Can't wait to hear it run. Fisherman
jeepistdougiowa :
Re: More Pics
Post by jeepistdougiowa on Jun 4, 2006, 11:08pm
Looking good!
saxon :
Re: More Pics
Post by saxon on Jun 5, 2006, 12:38am
Fisherman looks good, I did a commom thing, I bought a 70 j 4000 w/a buick,combined t/98-parts truck t/18 with the long bellhousing/cad 500 starter on same side as buick. saxon
saxon :
Re: More Pics
Post by saxon on Jun 5, 2006, 12:48am
Fisherman, I believe you,re from wash. st. as I, I have the parts truck buick eng, and the stock mounts/flywheel still, might be good spares? Got eng running before I knocked it in the head, no smoke or apparent knocks.? I,m just goofy and went with cad, longer eng P.I.A. could have just bolted in like you! PM me if you want. Dan
fisherman :
Re: More Pics
Post by fisherman on Jun 5, 2006, 12:56am
I live out in Snohomish. If your ever around let me know. Not to many fanatics like us around. I'd be interested in looking at what you've got for spare parts from your J truck. Todd Lucas Fisherman
saxon :
Re: More Pics
Post by saxon on Jun 5, 2006, 1:09am
Sounds good Todd, we,ll talk. signing out, pooped out! Dan Hansen saxon
