I am looking to find a trailer to haul. Which one would have been used with the Jeep? I dont know how much I will use it but it will look good in the parades.
Do you mean behind the M715 or to move the M715?
For behind the truck, a M101, M101A1, M101A2 or M101A3 all will fit behind it and be somewhat level. The M101 was designed to go behind the M37 and the early versions had the same lug pattern as the Dodge. The pattern was not changed for the M715. The M101A2 got the 8 lug pattern to match up with the CUCV trucks in the '80's and the M101A3 got offset axles and a slight lift to fit HMMWV rims.
For putting the truck on, something with no sides and at least 84 inches at the inner fenderwells and 18 plus feet long. 7,000 pound axles with brakes and 8 lug axles would be good. 16 foot trailers with heavy axles and rims will work in a pinch.
Do not exeed the M101 trailer, the truck is not made for more. But within the limitations: NO PROBLEM.
Wolf
