Stock M715 Pinion Angles?
Hi All,
I recently bought an M715 without the axles mounted and I am planning on mounting 1999-04 Super Duty axles on the factory leaf springs. As a result, I need to move the spring pads on the axles using the Barnes 4WD kit. Because I am not planning on doing a lift, I would like to mount the axles using the factory pinion angle.
Does anyone have the factory stock front and rear axle pinion angles, front and rear transfer case pinion angles, and front and rear driveshaft angles? I am sure they have been posted before but I searched and haven't found them.
