shackle flip questions .... need answers asap
i'm doing my rear shackle flip and i have somes questions because it ain't working like it supposed to ...
1- I have drilled the 4 3/8 rivets that retain the front hanger; but how do you fliped it ... it's not even moving ... does it weled from the inside ??
2- Axle problem ... i'm swaping a srw 14bolts ... with rear disk brake conversion .. is that normal that i will be able to bolt everything but due to the width of the stock leaves i will not be able to install my rear caliper ... does i really need to relocated the leaves under the frame ?
3- If i need to relocated the springs .... does anybody already done it ?? I need ideas hoe to mount the front hanger !!
Thanks ....
