Originally Posted by
Fastfrankie
You have more willpower than me. I returned the vette master about three hours ago, got my money back and will be installing the Wagner single resevior m/c Thursday or Friday evening.
I don't own a pressure bleeder...how were you able to pressure bleed each line separately off the master cylinder? Is there some sort of adaptor?
When I bled those brakes, I had my old man pump them manually so much, that night he could barely walk! I've never had to use a pressure bleeder so far with anything...well I am glad you found success.
Just for kicks, can you do me a small favor? Now that everything is working, have someone get in your truck and pump up the brakes and you go and crack a front bleeder. Let me know if the pedal drops to the floor and you get a steady stream of fluid...that will be a good test!
