2 Attachment(s)
M715 Fire Truck
2nd post...
My brother and I recently purchased a 1968? (I'll make sure) M715 that has been a volunteer fire brush truck for the past 35+ years. I've lived 5 miles from it all my life.
Very little rust and was maintained OK.
We got it running with a rebuilt fuel pump from 'Then and Now' and a rebuilt carb, some new batteries and fresh gas and oil.
I've put the 10-1331 master cylinder on, and am working on the brake lines now.
We've changed all the fluids.
First hurdle.....while refilling the transmission, before the fluid got up to the fill plug, fluid came out quite rapidly at the back of the trans and was running down all over, but the crossmember is in the way so I can't see exactly where its coming from.
Also, on the crossmember, on the vertical part, there is a hole about middle way up closer to the driver side, and fluid was coming out of that area too. What is that hole for? Its visible when under the truck looking at the back of the trans crossmember.
The trans is supposed to be filled up to the fill plug, correct?
Thanks, and I look forward to getting it on the road.
This site has been super useful so far.
Look at page 10 here http://www.m715zone.com/vb/pages/man...rksacrobat.pdf It shows bolts that can loosen and dump oil from the transmission, if it is leaking before it is full I would guess this is the problem. Yes fill to the bottom of the fill hole/plug.
5 Attachment(s)
Thanks.
That area is real gunky and greasy. I'll clean and check.
More pics:
Looks like you are well on the way to having a really nice road worthy truck. Brush trucks are climbing in value. With all the fire issues that seem to happen every summer now. Are you keeping it a brush truck or other have other plans? Looks like a fun project. Keep us posted.:)
Gonna keep it as is....may even try to get the fire equipment functional. For sure getting the lights and siren working.
Its a 10hp briggs powering the pump and a 150? gallon tank
Focusing on the truck first.
Welcome to the M715Zone!
I am just down the road from you in Sanford.
Nice looking truck.
1 Attachment(s)
Slowly moving forward...have a couple of questions:
1. I'm trying to put the air cleaner back on, and have a gasket on the carb, but the the lock screw fully tightens before the air cleaner is tight on the carb. Am I missing a piece?
2. can someone provide a pic of the back of the transmission crossmember? Like mentioned before, I've got gear oil coming out of the back of the trans and I think I'm missing a bolt or two? I need to see a pic of a stock setup.
thanks
Do you have the collar on the air cleaner all the way over the flange on the carb? It can be a little hard sometimes especially if someone tightened up the screw with the air cleaner off the carb or didn't have the air cleaner collar down on the carb all the way. The v in the air cleaner collar needs to be over the flange on the carb.
1 Attachment(s)
There are two bolts with a locking bar that hold the bracket to the transmission, I used teflon thread sealer on the bolts.
Those bolts LOVE to back out...teflon thread sealer is a MUST!!
I can't say for sure....but i think I'm missing those bolts.
Any clue of size/thread?
Thanks for the info on all of it.
I've got another cross member running behind the transmission, so I can't see where those 2 bolts go.
Is that extra crossmember a stock piece?
It's bolted, I can remove it....but is it stock?
There is a cross member directly behind the transmission, should be a shelf welded on it to mount the back of the transmission on, it has a large round hole in it on the RH side for the front driveshaft to pass through. I looked at mine quickly and if I recall it's bolted in.
2 Attachment(s)
Definitely bolted in, I had to remove mine to repair the frame in that area.
Ah the memories...
Yea, mine is bolted in. I'll take it off and check the back of my trans for those missing bolts.
I've now have a 1974 AMC 360/3 speed/tcase out of a J10 to go in the fire truck.
Any value in the stock, running and complete engine/trans/tcase? It has a rebuilt carb and new fuel pump on it. I hate to scrap it if someone can use it.
I'd place an add in the for sale section, even if you're giving it away so more people would see it.
yea....I'll advertise it, but not shipping it.
Might be worth more parted out. I've got $400 in carb and fuel pump $ in it. It runs, but needs a tune and new plugs.
1 Attachment(s)
stock engine is out. Next step is to mock up the 360/4speed/tcase assembly out of the 1974 J truck.
Stock engine, trans, tcase is for sale. Located near Wilson NC.
Attachment 3561
So I have a 360/4 speed/tcase out of a 1974 J truck that will be swapped in
What motor mounts do I need to get? I'm fine with modifying a bit, but would like to start with something close.
Thanks!
so I'm installing a J truck engine/trans/tcase as 1 unit
not using the stock divorced T case
will I have driveshaft length problems?
What transmission/tcase are you going to use? That will help people who did the same swap let you know what they did for drive line adjustments.
360 / T18/ D20
I have both the J truck and the M715 driveshafts
was hoping the rear driveshaft wouldn't be too long
thanks
changing gears....
gonna swap in a 2002 5.3 LS and a 4l60 and keep the NP200
does anyone have an example of what they did for Tcase lever brackets with an engine/trans swap?
thanks
In the course of this engine swap, I'm upgrading to a pedal mounted brake light switch.
I want to remove the pressure switch.
Anyone know the threads for a plug where the pressure light switch goes?
I thought it might be 1/4?, but not 100% sure.
I went with a pedal mount as well. I think that I browsed Napa until I found what I was looking for.
thanks. I'll start with that plug size and go from there.
any pics of your pedal mounted setup?
I will give it a look. It might be easier to snap a picture. Heading out for business for a few day, but will try to get it on the weekend.
