Correct hardware for attaching the torque reaction arm.
Does anyone have a list of all of the hardware/bushings that are needed to install the torque reaction arm? The pictures in the maint manuals don't help a lot, and I didn't see anything in the parts manuals. I'm quite sure I don't have anything that I should have, or maybe not in the right place.
I would also consider buying a handful of used (correct) parts if anyone has them, then I could look for new bushings later.
Thanks everyone!
Oh, I did find a 9 year old post that might have helped, but the drawing it referenced was gone, so I'm not sure.
Update: The final(?) piece of the puzzle.
I was just about to start calling around for bushings so I opened the -34 to use the picture in there as a reference. Then I noticed that I was in the engine section. And that's when the light came on. :idea:
Yes, the torque arm/transmission mount parts breakout is in the -34P, Group 1 Engine. Figure 5.
So now with all of the information in this thread, I should be able to make or buy everything I need to make this thing work right.
As my late, great aunt used to say, 'Until you're better paid, thanks a lot!'
1 Attachment(s)
COTS replacement parts list
This is just a list of part specs that I'm using to go shopping for the parts that I don't expect to have in the shop or find online as NOS. Maybe it will help save someone else some time looking them up.
Here it is in .txt format. Not very pretty, but it will do.
