anyone off the top of their head have a part number for an oil filter? also will any break fluid work or is there a certain type to be used in the m715 230 engine?
thanks
scott
thanks
scott
DOT 3 or 4 will work fine...DOT 3 is the most common in America.
For the filter, the Fram number is PH8A...but dont use Fram unless you want the cheapest piece of garbage for a filter made....go to Napa and have them cross the Fram number to their brand....if I could walk outside right now, I would get it for ya....also the WIX brand is real good.
The 230 uses the same filter as Ford V8's have from the mid '60's to a few years ago. Just tell them you need a filter for a '85 Ford truck with a 351.
I think the NAPA gold filter is 1515. Double check that though, cause it's been a while.
and wix is 51515 wix makes napa filters just add prefix # to napa filter. oil filters carry the prefix of "5"
i'll stop by NAPA on my way home from work today. thanks guys
scott
got the napa filter and brake fluid last night and replaced them. anyone know the part number for the air filter?
thanks again
scott
Which air cleaner you got....the small carb mounted one or the big underhood one?
I think they cab mounted one is listed in the parts list in the online manuals link...not sure on the other....
yeah mines on the carb
There is a part number for that air cleaner in the parts list.
ablinn did have them on ebay.
thank you brute4c
