Have any of you guys put A/C in a Kaiser? Looks like any of the flat firewall streetrod systems would work. Glen
Glen,
One other option might be to transfer one from a FSJ. I plan on pulling the one over from my donor J-10 and seeing if I can get that to fit.
Rich
That's what I am doing as well. Looks like a bolt in and should cool better being seperated from heater box.
i put a gen2 compac in mine. it was around 900, included everything except the r134. it cooled the truck fine on saturday where it was 90% humidity and 85 degrees. matter of fact i had to turn it down. i have a soft top too. heater/defroster work very well too. it has electric servos to control hi/low/defrost and heater valve instead of vacuum.
i didnt go donor because it was r12, and i didnt want to fight the r12 gremlins. also the vintage air unit is a recirculate only unit so you only have to run the heater/ac hoses through the dash (mine are through the stock square plate) and a 1" hole for the drain hose and grommet. all of my controls are mounted IN the glove compartment and i put underdash vents
i bought it from these guys. great customer service for getting me a non stock and non common a/c compressor!! its for sale for 895
http://www.autoairandaudio.com/compac.html
here they are on ebay by the above listed company
http://cgi.msn.ebay.com/ebaymotors/w...category=34197
also i would like to add the install is VERY easy and iirc vintage air has a 3 year warranty....
You can run 134a in a r-12 system as long as you go with new hoses, I've cheat with old hoses and been fine also. The liquid side runs higher pressures with 134a than 12 does. You WILL see a slight decrease in performance in a retrofitted system, but cheap talks to some of us.
i agree with cheap. i used USED parts where i could. the cheapest i could find a waggy a/c was 250 local and that did not include new hoses. compressor etc. compressors are 200 and hoses a hundred or so and that didnt guarantee the condenser (100+) was good and you really should replace the dryer (100) anytime you open the system.
once again i agree with cheap, sometimes it nice to add something you KNOW will work...
I am making my own HVAC system. I will post pictures when I get it to a presentable stage. Probably another few weeks. I am using a 90 Mazda 626 fan, cut down fan housing, evaperator, heater core, condensor, dryer and compressor. I just am making a new underdash housing out of 12 ga steel. Along with the vent baffles and such. I bought the car for the straight front front end, to repace a wrecked front clip on another 626, the head and auto trans. I paid $200 for the car and have already sold the trans for $400. Therefore, my a/c is going to maybe make me money. Figure that one out!
ohhh, i LOVE those deals!
i bought my frito lay truck with the diesel for 800. sold the tranny for 200 and selling the truck for 400 and have the rims and tires sold for 200. so while i was not paid to take the diesel, it was FREE to me
I can follow the math and it makes sense to me. I try to 'make' money on all of my deals in the end. Even if it takes a few years. I too love making money on parts that I bought. My wife just shakes her head and tells me it doesn't make sense.
[quote="mcinfantry"]i agree with cheap. i used USED parts where i could. the cheapest i could find a waggy a/c was 250 local and that did not include new hoses. compressor etc. compressors are 200 and hoses a hundred or so and that didnt guarantee the condenser (100+) was good and you really should replace the dryer (100) anytime you open the system.
Hell, I bought a running J-10 complete with rust for $300. Tranny shot, but a/c turns, motor runs, rest of drivetrain there, motor, hood and l/f fender going on the 725 along with a/c and hopefully, power steering. Nothing like catching a guy selling what his wife is tired of looking at!
Rich
Rich, the under dash deal will bolt right in if thats what you have.most the duct will work also. Defrost wont.
Hell, the defrost doesn't work so well in the J-trucks either, so no big loss! heheQuote:
Originally Posted by JeepistDoug/IA
Got to get the engine in first, and finding the right parts for that is proving fun! Putting Jeep 360 in, have flywheel, have bellhousing, haven't tested to make sure it's correct yet, going to have to change input shaft, and then I see this nice, running 2 1/2 on ebay for 2800! Doh! Anybody want an ambulance and donor FSJ??
Rich
