Oh, 1725rpm too. I'm seeing Marathon Eletric in the super thick new MSC catalog for $203.
Anyone work with this jazz or have good discounting?
Pool pump motor?
Just guessing.
Milling machine. Hoping to replace 3 phase.
No, I do keep up with your life enough to know that you have no pool and thus no pool pump- I was asking if a pool pump motor would work.
I do not know about phases....is that 220V, 3 wire? This pool pump motor I have is that.
I also have about a 2hp 110V fan motor that right now has mounting brackets, and a pulley on it. I shall take pics as they are better for matching this stuff up.
-B.
The side that the shaft comes out of needs to have a machined face so that it can be mounted there, not by a 'body' mount. Needs to be 1725rpm as well. Yeah, lemme know...thanks!
try this place http://order.harborfreight.com/EasyA...ht/results.jsp
sorry the link didn't go through. Try http://www.harborfreight.com then search "motor".
Already did. They didn't list any with the C-face front mounting design. So far, MSC had the best deal @ $203 on a Marathon Electric motor and Grainger had about $80-$100 more for the same style Dayton.
OK how about www.meci.com they are a surplus outlet and its hit or miss, but worth a try.
GREAT prices...just not heavy enough stuff. THANKS AGAIN!!
Tom,
Got a link to the page that has the motor you want? I want to see if it's anything like my pool pump motor. I think mine does have the flat side of the shaft, but if the diameter or mounting is the same then I shall be daymed.
-B.
