raven : 8 lug conversion
8 lug conversion
Post by raven on Aug 5, 2006, 4:22pm
Hey guys! I'm new to this board, and just picked up an M715 last saturday. I've owned one other, and have kicked myself in the arse for selling it ever since.
I've looked through the other threads and didn't see what I'm looking for. I've got a Chevy D60 for the front, and would like to swap the 5:87 gears over, and keep the rear D70. I have a 14 bolt, but 5:87 gears are not available for it. Problem is the wheel stud pattern on the rear. I know about the inner differences particular to the M715 D70, but was wondering what I can do to swap it over to 8 lug, if possible? If it's not something that can de done fairly inexpensively, I'll use the 14 bolt, and keep the 4:56's.
I will be doing a SOA/shackle flip, and have two sets of tires. 40" Boggers, and 45" tractor tires. One for wheeling, and one for moose hunting (I live in Alaska). It will also get a 350/TH350 & a NP203/D300 doubler.
Thanks for any help/advice!
Eric
kaizenator :
Re: 8 lug conversion
Post by kaizenator on Aug 5, 2006, 4:39pm
May I come up to ALaska and visit? I've always wanted go up there.
kwai :
Post by kwai on Aug 5, 2006, 5:01pm
I would use the 14bolt and keep the 4.56's. You will be $$ ahead at the end of the day.
With 350/auto/doubler you should be good with 4.56's.
kaizenator :
Post by kaizenator on Aug 5, 2006, 7:27pm
Yes about the 14 bolt, keep in mind the D70's low spline count (I've never broken one though, but i have the 230 in mine and no 46" tractor tires...wish I did though). If you already have matching R&P in the ChevyD60 and the 14Blt, you just need lockers for them. How close to 5:87 can you get a R&P set for the 14blt? (might be close enough). You can, however, bore the spindles from an eight lug D60 if you had the means.
Check this out:
http://www.pirate4x4.com/tech/billavista/D70/D70.htm
robertcowan :
Post by robertcowan on Aug 5, 2006, 7:38pm
THERE ISNT ENOUGH MEAT IN THE HUBS TO REDRILL THE BOLT PATTERN.
robertcowan :
Post by robertcowan on Aug 5, 2006, 7:39pm
USE EARLY DODGE DUALLY HUBS TO GET 8 LUG PATTERN
mikel :
Post by mikel on Aug 5, 2006, 8:51pm
Will the M715 axleshaft flange fit the dodge hub?
Quote: <TABLE class=bordercolor cellSpacing=1 width="90%"><TBODY><TR><TD width="100%"><TABLE class=quote cellSpacing=0 cellPadding=2 width="100%"><TBODY><TR><TD width="100%">USE EARLY DODGE DUALLY HUBS TO GET 8 LUG PATTERN</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
tacomainoh :
Post by tacomainoh on Aug 5, 2006, 10:17pm
Seriously
just use the GM stuff. It's a lot easier.
raven :
Post by raven on Aug 6, 2006, 12:36am
Quote: <TABLE class=bordercolor cellSpacing=1 width="90%"><TBODY><TR><TD width="100%"><TABLE class=quote cellSpacing=0 cellPadding=2 width="100%"><TBODY><TR><TD width="100%">Seriously
I'm not concerned with "easy". However, since I live on an island in Alaska, good used parts can be hard to come by and shipping is a killer. My main concern is cost if I can't find the right stuff to work.
Quote: <TABLE class=bordercolor cellSpacing=1 width="90%"><TBODY><TR><TD width="100%"><TABLE class=quote cellSpacing=0 cellPadding=2 width="100%"><TBODY><TR><TD width="100%">I would use the 14bolt and keep the 4.56's. You will be $$ ahead at the end of the day.
This is my thought as well. Would allow me to run her down the highway without pegging the redline too. BUT, the allure of 5:87's is too much to resist if I can make it happen without breaking the bank.
Just the hubs? They will work with the stock spindles, bearing, races and shafts? Or will I need to use the spindles, bearings and races from the donor axle as well?
This is the kind of info I'm looking for. I may be able to find an old Dodge dually D70 laying around here. If this will work, and I can find one, I'll go that route. If not, I'll stick with the other plan.
Thanks,
Eric
bluesman2a :
Post by bluesman2a on Aug 6, 2006, 2:31am
Quote: <TABLE class=bordercolor cellSpacing=1 width="90%"><TBODY><TR><TD width="100%"><TABLE class=quote cellSpacing=0 cellPadding=2 width="100%"><TBODY><TR><TD width="100%">I will be doing a SOA/shackle flip, and have two sets of tires. 40" Boggers, and 45" tractor tires. One for wheeling, and one for moose hunting (I live in Alaska). It will also get a 350/TH350 & a NP203/D300 doubler. </TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
I'm on the tail-end of doing all this work on mine. I did a lot of research before I started. Some things I found:
1) Use the CUCV (60/14 bolt) GM axles. What you spend on the axles you will get back in savings on brakes, cheaper wheels, and better gearing.
2) If you DO go with a doubler, a 300 won't cut it. These trucks are too heavy and at that gearing the 300 becomes marginal. I went with a 203/205 doubler, super beefy. If I were spending the money TODAY, I would call the guys at Stak 4X4 and get one of their three speed monster boxes with an OD on it (I drive my junk everywhere). If you do go with the 203/205, call the guys ar NorthWest Fab, they are relatively close to you (BC) and are great to work with (although can be a little slow).
3) Th350's can be built, but again for these big trucks, the TH400 can be made much more bullet-proof. I know-not how, I'm not a slush-box guy, this is my 1st in a trail-rig, but that is what every technician told me when I demanded "bullet-proof".
Enjoy, and hope some of that helps!
tacomainoh :
Post by tacomainoh on Aug 6, 2006, 3:37am
oops
I missed that you are in AK!
In that case, I definitely recommend a late model swap, either GM or your choice, but something more recent.
GM stuff is fairly easy to come by and there is lots of aftermarket support. I agree with you wanting to be able to get parts in the middle of nowhere, which is why I am also a big fan of GM 350's: they came in everything, and everything interchanges (mostly.;)
anyway.
I second the 203/205 Doubler, as well as the Northwest Fab recommendation. If memory serves there's is a clockable, weldable design....
also if you get a set of 4.56 CUCV axles, you can use the rear Detroit for the 5.87's and you'll only be out the cost of ONE locker.
TH400's can be made burly pretty cheap. Just get a decent cooler.
bluesman2a :
Post by bluesman2a on Aug 6, 2006, 12:47pm
I second the 203/205 Doubler, as well as the Northwest Fab recommendation. If memory serves there's is a clockable, weldable design...</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
Clockable: Yes...
Weldable: Not so much
They use a series of mounting holes on two sides of a sleeve for an insane amount of adjustment.
http://www.northwestfab.com/203-205a...nstallpg3.html
http://www.northwestfab.com/images/i...on/nwf043r.JPG
tacomainoh :
Post by tacomainoh on Aug 6, 2006, 12:58pm
oh that's right!!!
I am thinking of someone else. Jed's I think. You weld it up yourself. Northwest is the superbling clockable thing. Thanks for the pic!!! hahahha
oilcan :
Post by oilcan on Aug 6, 2006, 1:03pm
When I bought my 725 from a member in VA, it had the 8 lug conversion started. My memory is kinda fuzzy, but I think his username was PaulC, and he did a writeup on the old board about it.
If you want, I can dig up his email address since I haven't seen him here yet.
