dodge power steering pump
Post by uscgmatt on Jul 28, 2006, 6:00pm
Does anybody have any idea how to make a template of the mounting holes? There is no way to stick a scribe through to mark them. The pump is out of an 85 D350. Thanks
Matt
Matt
Re: dodge power steering pump
Post by fisherman on Jul 28, 2006, 6:20pm
Which mounting holes? On a dodge or your M-715. Your trying to mount the power steering pump to your 230? Did you get your power steering box installed? Fisherman
Post by uscgmatt on Jul 28, 2006, 6:23pm
I am trying to mount the steering box to the frame. The pump is on a 360 in the truck.
Matt
Post by fisherman on Jul 28, 2006, 7:41pm
OK you said pump, not steering box. The dodge 360 is mounted in your M-715. You need a fullsize jeep power steering box and a new pitman arm. This will bolt up using the 3 original factory holes your truck came with. I suggest utilizing the fourth hole on the Jeep power steering box. I believe most have 4 holes. I marked for the fourth hole when my box was mounted up tight. Remove the box, I torched through the frame, 3 thickness of steel. Used a sleeve of steel tubing and ran it through up tight to the fourth hole on the box. Tacked in place and make sure a long grade 8 bolt will go through from the outside of the frame to grab the ear on the steering box. Remove box and fully weld the tube steel sleeve. Grind or cutoff excess from outside of frame. I bolted mine up with locktight and washers. I'm not sure if using the fourth bolt hole on these boxes is necessary. I don't want any chance of steering box failures, so I took the time needed to insure a very sturdy mounting. Especially if you plan on using large tires or wheeling any. This was my solution and it looks nice too. I used a box from a 69 j300 and a zone member had the right pitman arm, I purchased from him. Good Luck Fisherman
Post by jeepistdougiowa on Jul 28, 2006, 7:46pm
Use the forth hole...I've busted the three holers off the frame three times in the past...but I tend to drive like an idiot at times
Post by uscgmatt on Jul 28, 2006, 8:25pm
I dont have a jeep steering box. I am trying to use the dodge steering box. The old steering box hade a homemade mount (fire dept.) which was in bad shape. The dodge box mounts on the outside of the frame. The hard part is that the back two holes are almost two far apart to fit in the frame. Parts are kinda hard to get up here, so I am trying to make do with what I have.
Matt
Post by fisherman on Jul 28, 2006, 9:49pm
Fabrication sounds like your only option.
Post by luckypabst on Jul 29, 2006, 12:54am
If you can get a straight shot to the front side of the holes, use one of these:
http://www.use-enco.com/CGI/INSRIT?PMAKA=830-0100
If the holes are covered by part of the casting to where you don't have a straight shot, use something like this:
http://www.use-enco.com/CGI/INSRIT?PMAKA=240-1904
In the case of the second option, you'll have to determine what exact size you need since I don't know what size the holes are in the steering box and they offer the blind hole spotters in 1/32" increments.
Chris
Post by uscgmatt on Jul 29, 2006, 1:04am
Those tools are pretty neat and cheap.
Matt
Post by jeepistdougiowa on Jul 29, 2006, 1:12am
Have any threaded rod?
Any reason why you couldn't run them though far enough to stand it on a piece of cardboard to make your template?
Post by luckypabst on Jul 29, 2006, 1:23am
Matt,
Enco is known as a fine puveyor of Chinese machine tools. They also have smokin' deals on quality American goods too but I posted the cheap alternative since I figured it may be a low use item for you. Get on their website and request a free catalog. Lots of goodies for tool s like myself.
Chris
Post by uscgmatt on Jul 29, 2006, 2:40pm
I fianlly tried the cardboard idea yesterday afternoon and it seems to work. But I am outa time for now. I am headed to Lackland AFB for training for the next 2 weeks. Hopefully I will get this done when I return. Chris, I will be requesting a catalog for sure.
Matt
Post by maccj715 on Aug 6, 2006, 4:53pm
i would ditch the idea and go with the fsj box i did mine yesterday 8/6 i used the box out of a j10 pickup 80? dont know th exact year the cab was burnt up there were no mods needed at all even the pittman arm was the same it was 30.00$ at the local pic a part yard still need to mount tthe pump tho havent bought that yet i am going to modify for the fourth bolt hole dont like the idea of leaving it hang in the breeze took about an hour to do but i went slow with it
