Anyone care to recommend a flaring kit and/or brake tube bender??
Just about any of the double flaring tools sold by NAPA and the like are the same stuff. Just try to avoid the Chinese ones if you can.
As far as a tubing bender, I wouldn't buy one anymore. Just go to the local NAPA and get the green coated polymer brake line. You can bend it by hand or around a round object like a piece of exhaust pipe without it kinking.
Get the flare tool. You need to learn how to use it anyway. I buy the long sections of tubing and more nuts and cut to the length needed.
Yeah I'm gonna be proactive and just replace all the lines on this thing as I've swapped to the 60/14 anyway. Might as well start from scratch. Had a small leak in the front line-pinhole somewhere where it jumped over to the passenger side. Eastwood has the spools of line that I've been told is of good quality and pretty easy to work. I was just concerned with tight bends-such as going into proportioning valve.
Once you get to using the flare tool, you will want to replace more line just to play with it. Do them all if you can since line is basically cheap insurance compared to a pedal slapping to the floor.
As everybody mentioned, I also pretty much replace all the hard lines on any vehicle of question. Cheap insurance.
The flaring tool comes in handy for those times when the line is just a little too long for that last section and you really want a nice clean install.
Do you guys use a different size hard line when replacing, or just the same as stock?
I used 1/4" tubing. A blue point flare set and unknown tubing bender. Yesterday I was taking a look at my friends 47 chevy 1 ton restoration I'll be lending a hand on that one. He showed me a Boeing tubing bender he came up with while working there. Truly an aircraft bender with incredible quality and adjustability, I was jealous.
I've not gotten that far yet--Was looking at the 14 bolt splitter in the back and it looks like the same size line??? Maybe I'll get more involved tomorrow. Wheeled the rear of the frame and used eastwoods rust converter, encapsulator and chassis paint. Then messed with wiring.
I think I'm going to drop the hardline to the center of the 14bolt just like the chevy had and split to either side. In front I believe I'm going to leave as is with line to either side.
