Anyone have a picture of an M14 in the behind the seat rifle mount, mine does not want to fit.
I'm not possitive because I don't have the gun mount in the stock location any more due to moving the drivers seat farther back. But I believe that for a M14 to fit in, it has to be positioned with the mag well facing in towards the battery box. The stock may not fit totally flat in the base, but as long as you can position it where the rifle is mainly flat against the upper mount it should hold fine.
Dave
1953 Dodge M37 weapons carrier http://www.davidallenracing.com/M37.htm
I have one at home. I can look tonight and see if I can find it. It fit with no problems.
I have a pic Kaiserjeeps posted a long time back with a M1 Garand in the holder...does that help?
I just took some pics in the dark. Give me a few minuites to clean them up.
Thanks guys, I'll try it again.
Anyone with a pic of a dash mount on the pass side?
I never looked too close that your pic before Al....a clip on a Garand????
30 carbine maybe...
Magazine:
http://www.ar15-rifles.com/shop/images/50439.jpg
Clip:
http://www.tickbitesupply.com/m1gclip.jpg
http://www.olegvolk.net/gallery/d/15651-5/clips0504.jpg
Or....
Magazine:
http://covers.magazine-agent.com/ima...8718.JPG&h=650
Clip:
http://i47.photobucket.com/albums/f1...n/hairclip.jpg
http://www.linksoflondon.com/dynamic...ip-image-1.jpg
As others have mentioned, M1 Carbine
Upon further research, it looks like it is specifically a M7 bayonet knife.
"The M4 bayonet formed the basis for the later M6 and M7 bayonet-knives."
http://img91.imageshack.us/img91/603...ne70006pd3.jpg
http://img91.imageshack.us/img91/idm...jpg/1/w504.png
M2 Carbines with 30-round "banana clips" in a radio jeep, Korea, 1950.
http://img378.imageshack.us/img378/4...ne70007dn1.jpg
http://img378.imageshack.us/img378/i...jpg/1/w504.png
Soldier carrying M2 Carbine with 30-round "banana clip" and bayonet, Korean War.
Photos courtesy of Olive-Drab website.
http://www.olive-drab.com/idphoto/id..._m1carbine.php
Geeez a thirty round magazine? I thought the largest capasity magazine the US military had was for twenty rounds?? Well thats what I get for thinking, after all we did create Flash Gordon and Star Wars and the cowboys thousand shot revolver! Need to get out to the movies more must be out of touch again!
Binford you for got the all mighty "Jesus Clip"
The standard magazine for an M-16 is 30 rounds, . .has been for 20 years. Anymore about the only time you see a 20 round magazine is at the firing range. The US military experimented with larger magazines, but found that there would either be too much spring tension when they were fully loaded, or not enough when they were close to empty, . .either way causing feed problems. . .
Binford, you forgot one other type of clip in relation to ammunition, . .the "strip-clip" that holds belt-fed ammunition together that is separated by the action of the machine gun, . ..
I'd vote it's an M2 carbine. Prolly an M7 bayonet, it's not an M8A1 (M16) as someone mentioned.
Anyone have a good pic of an M16A1 (or earlier version M16) in either mount?
Yes, or this "stripper clip" as well:
http://www.cheesepatrol.com/images/sks/sks4.jpg
Kaiserman, Beast has a great shot of an M16 model in a dashboard mount.
I have a pic with my M16a1 in the commanders mount on the dash of my M715. I don't have it behind the seat because I modified the seat to sit farther back which left no room for the gun mount back there.
http://i454.photobucket.com/albums/q...s/DSC_0331.jpg
I aslo have one of the M14 in the M37 and one of another M16a1 in my Deuce.
http://i454.photobucket.com/albums/q...s/DSC_0330.jpg
http://i454.photobucket.com/albums/q...s/DSC_0332.jpg
Dave
I call everything that goes int or attaches to the gun with ammo in it a clip...I rarely ever have used magazine except for a pile of paper with staples in the middle....
Sorry for the confusion.
It's a M-2 carbine(30 cailiber)very weak on the knock down,nothing like a M-1 or a M-14,was suppose to take the place of the greese gun,(.45 cal-blowback sub machine gun),was used in the later part of WW-2,Korea and Vietnam .
