Sub, it was late when I posted (for an old guy like me), I gave you some bad info. I believe the stock distance post to post is 22.5. Check this thread out:
http://www.m715zone.com/vb/showthread.php?t=18416
The hole to hole measurement won't make any difference if you are using the Wild Horses kit. They are two separate motors, unlike the CJ/YJ wiper setup which has a transmission and one motor on the right side.
The wiring length would be the only thing that would be a variable between the two motors, but that could be temporary until you get it home.
Thanks Randy, I was paying less attention than I thought I was. I had a vision of sub welding up and redrilling a hole based on my post :eek:
Wont matter with separate:cool: motors
Actually, I'm wiring the kit then sending it to the PO (4000 miles away) to install. Having that measurement kind of close will help a lot!
...and it did help a lot! Thanks! The PO said that they were a complete drop-in.
Wild Horses shipped the kit reasonably fast- about a week to AK. They charged me $45 for FedEx. I think the motors could have fit in a Priority Flat Rate box for $15, but they didn't think so. Whatever.
The extra nuts I added to my order on the phone for $15 must fit a Bronco, because they're completely the wrong diameter and thread pitch for the wipers I got. An email on the subject was ignored. With shipping and going to the PO, it's not really worth my time to press it over $6 nuts, but now you know.
The 1.5" spacers from Lowes worked perfectly. I had to run a drill through the big ones to get them over the brass threads. A little sandpaper work would probably do the trick too, just smoothing out some roughness inside.
I noticed two things while Googling these motors:
-boat folks like them too, but pay a lot more. Wild Horses was the cheapest I could find.
-they come in different offsets (length of threaded shaft). Shorter ones might not require the spacers. I'll know more about that when I see the truck.
Thanks for the info about wild horses. It may save someone an unwanted headache. Good info on the wipers too
I've been running one of those cheap chinese things. (broke one of them installing it..) Ready to upgrade. This thread inspired me but I'm cheap.
I ordered 2 of these wiper motors.
http://www.ebay.com/itm/New-Windshie...FWL2bc&vxp=mtr
Now to hunt around for a switch...
I think this is one of the threads on here that would be so great to be able to see Randy's build pictures from the first page or two of this thread. I am so wanting to give that set up a try on my M725, but I'd love to see the pics first. It looks like they have been removed. Am I the only one that can't see the pics??
Cheers,
Bryce
Tomorrow I'll try to get a few pics of my setup like his.
