You are amazing AL!!! Great work as always...pretty!
Did someone put the parking band onto their NP205? Maybe I'm mixing up moving the parking brake when they also moved the drive shaft over.
Yes, a NP200 parking brake can be bolted to a NP205. However, the NP200 brake mount/output bearing housing has to be machined to fit.
Hi Al, I just tried to message you but your inbox is full.
OK, I just deleted a bunch. Send away...
Good to see you again and have lunch with you Thursday Al. And yes we talked M715s in addition to coming up with solutions to all of the world's problems, our country's problems, and Jeep problems. Looking forward to seeing your rig out camping this summer. We might have to have a PNW FE this fall, sounds like there are a number of guys here in the PNW with M715s.
Sure been a lot of distractions. But I have been making wires for all the add on's and untangling and feeding wires to their destinations. Pretty much just feeding them through the rocker switch holes and I will terminate each wire at the dash later. I have been using weather pack connectors everywhere. Nice plugs.
Wires hanging just about everywhere.
https://hosting.photobucket.com/8af5...720&fit=bounds
The cab. It is slowly getting cleaned up. There will be some extra wires. I did not need 26 circuits but I wanted the waterproof fuse block. I also think some of the wires are undersize. Like the cigarette lighter feed. Same with the HEI distributer feed wire. They are a bit small in my opinion. Should be 10Ga to say the least.
This is going to take a while. Lots of wires to add. Like turn signal and 3 lever light switch wires. One at a time.
I am still waiting on my headlight relays still. They are flosser relays. Top quality German parts. Perfect.
I don't think Glenn has posted anything on it. It has been tentative and something we want to do. For years now..LOL I think we should make it happen. I am sure he will see this and I may just shoot him a text. He is in Post Falls just past Spokane. I need to get my truck done. I'd like to run it a few months to make sure all is well on it. I sure did not pick the right tires for much hiway running. I bet they go away fast. Regardless I REALLY want to get as much camping in this summer as possible. Anyway, glad you said something Twobit...
Al that rig looks awesome. Glad to see you're getting close to running it.
