fisherman :
Re: Doubler X-Member
Post by fisherman on Jun 19, 2006, 9:52am
What does the Mico-Lock setup entail? I have front discs stock axles, rear drums. A seventies duel master cylinder non power chevy master. I will be plumbing my own lines probably like you stated above. Looks to fun,, Fisherman
bluesman2a :
Post by bluesman2a on Jun 19, 2006, 11:47am
Quote: <TABLE class=bordercolor cellSpacing=1 width="90%"><TBODY><TR><TD width="100%"><TABLE class=quote cellSpacing=0 cellPadding=2 width="100%"><TBODY><TR><TD width="100%">What does the Mico-Lock setup entail? I have front discs stock axles, rear drums. A seventies duel master cylinder non power chevy master. I will be plumbing my own lines probably like you stated above. Looks to fun,, Fisherman</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
A Mico-lock is what they used on a lot of heavy equipment back in the day. It's essentially a valve that mechanically maintains pressure on the calipers without any electrical input. Some of the cheapo linelocks have solenoids. With those, when you lose electrical, your e-brake cuts out.
Part number 02-640-125 on page 3 from here:
http://www.mico.com/litpdf/80-950-152.pdf
The mico-lock supposes that you also have hydraulic pressure, so it's not a mechanical e-brake, but it's good for parking and the like. As such you have to plumb it in between your MC and the calipers. See pic of the control here in red:
http://www.sjmembers.com/gallery/alb...0433.sized.jpg
fisherman :
Post by fisherman on Jun 19, 2006, 6:46pm
Thanks that looks like it may be an easier install than swapping my driveline drum from the 200 over to the 205. Fisherman
robertcowan :
Post by robertcowan on Jun 19, 2006, 10:28pm
if you want all 4 wheels brakeing and you have a split m/cyl. you need 2 of these.
barrman :
Post by barrman on Jun 20, 2006, 9:51am
Doug has a lock on his brakes. He used it to full advantage at the FE. If you plan on getting stuck on the side of some hills, put one on.
