Here's what il look ....
The bellhousing bolts are M10x1.5 and the tranny bolts are 3/8 NF
http://www.rockcrawlerquebec.com/kam...ineadapter.jpg
So when you had the truck running and driving with the 6bt how did it stop with the 2.5 ton rockwell drum brakes on all four corners? I read futher back in the build you were wanting to go to disc wheel brakes, any particular reason for this?
It stop real nice. Good brake modulation but had to change the master for a bigger one because it was braking but not enough in emergency situation with the stock oem unit. Why i want to upgrade .... only to have better brake ( you never have too much brake with a big truck ) I have some parts for my disk brake conversion but need to get another 2 galipers and found a massive hat rotor so i can fit a real heavy duty system .... but as you can see right now my priority is to have the truck back on the road
Quick week update ....
The SAE adapter is almost finished ... need to tap 10x 3/8 holes but only 2 is needed for the first test fit.
Also i'm working with a buddy to have a custom built clutch with twin disk and heavy pressure plate made. They are VALAIR's distributor in Canada so they are looking to make a 14" clutch kit for the spicer 3053.
First try this morning ..... PERFECT fit !! Just need to countersunk for the M10 bolts and paint it .... Hope to bolt everything together next weekend.
http://www.rockcrawlerquebec.com/kamikaze/adapter.jpg
Nice job--now hurry up and get it back together!:)
Gonna be awesome!!
Just finished the counterbore of the adapter. It may not look like that but it's more time consuming then what i was expected. But now the adapter is done and i'm still waiting for clutch news ..... The M715's going to my friend shop in around 3 weeks to have the powertrain and the airbags plates installed.
http://www.rockcrawlerquebec.com/kam...redadapter.jpg
Last fit and everything's perfect.
http://www.rockcrawlerquebec.com/kam...nnyadapter.jpg
Have order the clutch assembly. Made by Valair .... rated to 750 pounds of torque 14" stamped steel ceramic .... it's essentially the same as a fuller 14" but ceramic instead of organic. They can make me a real one with dual clutch that will handle 1200 + .... but it will be too expensive for now. The priority is to have the truck running.
Have the 4" tubing , elbows and t bolts to finished the snorkel assembly and the exhaust.
My laser cut airbags plate just went in.
Order a 1g air tank be me modified for my hydrolic setup.
So the truck will soon be moving again .... soon !!! :D
