I used the Deuce hardware and shortened about 8" then with 1" spacer i just bolt it through the bed using 3/8 bolts
now i'm working on adapting the tranny to the engine and mating them to the tcase using what i have in stock ...
But i will need an SAE adapter from Phoenix Casting ... or find an Sae#2 to #3
A freightliner FL70 flywheel and a 14" clutch
Also i hope to have respond from a guy at JP Magazine ( Pete Trasborg ) about the flange on the 205 that will allow stock 1500 series driveshaft to be bolted. ( will need two of them )
This is the flange needed ---)
http://image.jpmagazine.com/f/914058..._five_05_z.jpg
I just ordered a flange from http://www.redbarncustoms.net to bolt a stock deuce driveshaft to a NP205, they can do custom work so you might want to give them a try. They specialize in rockwell stuff.
For the engine adapter .... $550 from Phoenix !!! WOW that's not cheap ... so i decide to make my own. One call to a friend ... took all measurements ( phoenix send me the drawing of the adapter 26-0368 ) and have 2 metal rings laser cut. I order them with .250 pilot holes to be sure that they will be the good size before tapping it with 3/8x24 bolts. So i will have a better ( build not bought ) adapter and it will cost under $200 with all the hardwares. Since the flywheel will cost around $1k .... that $350 rebate for the adapter will be appreciate. The only drawback is that i will have .250" of setback instead of .130" because 1/8 of metal bolting the tranny around the bellhousing make me asking question if it will be strong enough ... so when in doubt make it stronger .... so this is why the increase to .250 thickness.
I missed what your plans are, sorry. Would a deuce flywheel fit your needs? I have some extra. Also, the trans to motor on a deuce has an adapting plate(to go to a bigger circumference), I bet I have one of those too if it would help. I second redbarncustoms, good guys there.
Your build is great, I am starting mine with a Cummins and a Fuller 6spd from a Ford F800.
Does your 14.00 XL's source have any more tires?. I plan on running the same tire.
Yes they have more and sometime they received new never mounted 14.00 XL
Call Ken from Kublos Surplus at (570) 663-2805 It's a great guy and his prices are real good.
http://www.kublossurplus.com/
Thanks for the offer but i have the adapter you are talking about but the have an odd bolt pattern on the engine side.
I order mine today .... laser cut to my specification.
Let me check for the flywheel ... i'll take mesurement this weekend about the size and teeths
Thanks for the tire info.
